Hi!
I`ve reinstalled my OS (windows 7 64bit) recently and installed Inventor 2014 en. After this I can`t use Content Center files. After clicking on the "Place from Content Center" button - nothing chappens. I`ve reinstalled the Inventor, installed SP1 - still the same. Does anyone has any idea what is wrong? I`m using Single User Priject, whole Content Center libraries are installed (I`ve checked it).
Before OS reinstallation everything was correct.
Please help 🙂
thanks a lot,
Marcin
Solved by Curtis_Waguespack. Go to Solution.
Hi amcik,
I did just find this post which might fit your situation:
I hope this helps.
Curtis
It works! I can`t believe it 🙂
Finally! 🙂
I`ve run Inv as NOT administrator. Everything is ok, CC dialog box appear and works properly.
It is really suprise for me - how is that posiible?
Thanks you guys for your time!
Marcin
May I make a suggestion?
I noticed that in the Project file you referenced it is missing the Libraries section, and it is replaced by Content Center Files. I would create a new .ipj file and accept the defaults. It may be a possibility that your IPJ templates are corrupted. The normal look of a project file should contain a libraries section, your example does not. If you look at Curtis W. project file picture you will notice a main section "Libraries". just above "Frequently Used Folders". Also I notice that your content center Data base path "The recipes" points to the location for the used/placed content, not really a good configuration. Curtis and Cadmanto have noted this as well, so I would test create a new .ipj and fix your path loop error.
