I'm sorry if this isn't in the proper subforum, but I'm facing a strange problem with Inventor's content center. For many parts generated the iProperties are improperly generated, specifically the finished weight of the part. Sometimes a finished weight is generated with two decimal points. This normally wouldn't be a problem, but when I try to check the part into SmarTeam nothing happens. If anyone has encountered a problem like this, I'd appreciate some advice on the situation.
Thanks!
There are a couple of steps you need to take to fix this. The cause of the extra decimal places is the template you are using for your CC part.
(Not to be confused with your normal part/assembly templates - CC Family templates are very different!)
Job done. You may need to refresh CC files in your assemblies for this change to propogate.
