Inventor General Discussion
3 Kudos
Post 11 of 23
Re: Construction Circle in drawing
02-07-2014 03:43 PM in reply to: mariont55
Thanks guys for trying to help out.
Yes importing model sketch into the drawing works. However, this is not what I'm trying to do. I'm trying to come up with a system where my model is fully parametric (variable). This is why I'm employing excel to drive my manufacturing stages of a part. That appears to work. Drawings of the different manufacturing stages of the model are very important. This is what I send to my blank suppliers and post on a shop floor at the various manufacturing stations. It is our basic and required process control documentation.
It's just like I thought, when you import the model sketch into the drawing, it shows the whole sketch and all it's features. Where I only wanted to display a part of it, like a construction circle. In diesel fuel systems industry, we make meny components that require conical surfaces. Most common (and best) way to dimension location of a cone is to use a gage ball. This is also how the parts are getting measured (over a physical gage ball).
JD suggested I could also do some sketching in drawings. This is not an answer either. With and average model, there are meny drawings associated and each one representing a differnt stage of manufacturing step. Quite often models need revisions and changes. I don't want to be making sketches on all of the resulting drawings. Plus I don't even see a way to attach my sketches to the part in the drawing. So when models gets revised, the drawing sketches need to automatically change as well. When you sketch something in a drawing, it is just an independent sketch and does not belong to a variable model.
Ability to retrieve a part of a model sketch would be a good solution. This is already available for dimensions and model work features. Why not for model sketch features ???.
At this point I'm not sure what to do. Since the demise of Mechanical Desktop I'm beeing pushed to come up with alternatives, but I'm starting to have doubts in Inventor ...
For everyones info. In Mechanical Desktop, I could easily add a ball as a separate part and include it in my drawings. The process takes a few seconds. In the individual drawing views I can turn the visibility on and off as I need it. Process was painless and quick. Seems like the Inventor is a step back in meny aspects.
I'm wondering if anyone from Autodesk development team is reading any of these posts. They can sure use some improvemnts ...
64 Kudos
Post 12 of 23
02-07-2014 04:00 PM in reply to: mariont55
In the drawing, if you select a view before starting the sketch it will be attached to the view and you can project lines, etc. from the part.
Or
Make another sketch in the part - project your circle from the sketch you constructed everything in, now you have a sketch with only the "ball" that you can import.
And the best solution
Do it the way you used to do it - the way it actually gets made: Make a ball and put your part into an Assembly with that ball and make the drawing of the assembly.
Getting the right answers is about asking the right questions - this has been going along trying to help get your sketch into your drawing, if you had said "I want to add a gauge ball in my drawing" from the start you would realize that this isn't an aspect where Inventor is a step back.
Distinguished Mentor
139 Kudos
Post 13 of 23
02-08-2014 06:49 AM in reply to: dan_inv09
What Dan said.
See attached
2,129 Kudos
Post 14 of 23
02-08-2014 06:53 AM in reply to: mariont55
mariont55 wrote:
.... Plus I don't even see a way to attach my sketches to the part in the drawing. So when models gets revised, the drawing sketches need to automatically change as well. When you sketch something in a drawing, it is just an independent sketch and does not belong to a variable model.
..but I'm starting to have doubts in Inventor ...
You have a longgggg way to go to learn Inventor techniques.  How long did you use MDT.  Do you have any idea how long it took you to master MDT?  Because I take students through 4 yrs of study (at one time with MDT) I end up with seniors in the spring who almost seem to read my mind as I start making suggestions to freshman in the following fall where I forget they aren't my pro seniors.  I am immediately transported back to my first stumbling steps going from MDT to Inventor.  We tend to forget what it took to master a tool.  (the first semester we started with Inventor I told my students, "We will look at this Inventor program, but MDT is my favored program.  By the middle of the semester we no longer even bothered to open MDT - it was obvious an antiquated beast.
A year from now you will come back and revisit this thread and chuckle with the same realization.
Push forward knowing that there is an easy and logical way in Inventor - a logical way that makes MDT an antiquated beast.  A beast that should have been put to rest 12 years ago.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
3 Kudos
Post 15 of 23
02-09-2014 04:54 PM in reply to: mariont55
Guys,
Your help is greatly appreciated.
I suppose it took me a while to learn Mechanical Desktop. Learning goes on for ever and pretty much unnoticed, untill you look back and really think about it. Thank you all for your patience with me.
3 Kudos
Post 16 of 23
02-09-2014 05:11 PM in reply to: rdyson
It's taking me a while to get the hang of this. I'm still having trouble with just being able to display model sketches in my drawings. They don't even show up in my drawing browser. Not sure what I'm doing wrong.
The attached drawing looks pretty good. This is exactly what I was after. In the drawing there is a detail "B" and it shows the 1.5mm ball. How would I also display the larger 2.5mm ball in that view ??? Can you step by step let me know how to do this ?
Valued Contributor
45 Kudos
Post 17 of 23
02-09-2014 09:01 PM in reply to: mariont55
It appears that due to your part being an iPart there is no 'sketches' in the model files for the drawing to retrieve.
I'm not sure how best to handle that (there may be a quick fix)
Otherwise my only suggestion is to follow reality... this drawing needs to be based off an assembly file as you want multiple parts to be on the sheet. (and on the factory floor the guys will be making an 'assembly' to perform any measures with the gage balls)
139 Kudos
Post 18 of 23
02-10-2014 06:25 AM in reply to: mariont55
Maybe these two images will help you figure it out
3 Kudos
Post 19 of 23
02-10-2014 06:12 PM in reply to: rdyson
Thanks. This is helpful. For some reason, I can only show the small or the large but not both balls at the same tine ???
139 Kudos
Post 20 of 23
02-10-2014 09:02 PM in reply to: mariont55
Create a new view rep in the ipt
