Is it possible to constrain sketch entities, (like lines), to a plane, (make the line and plane coincident)?
If so, how?
Thnaks,
Craig
Solved by Cadmanto. Go to Solution.
Yes, but you should probably attach your file here to make sure the problem is understood.
Craig,
Welcome to the forum.
In your model sketch, select the plane and select the project geometry command.
Then select the plane. Holding down the Ctrl key, select your sketched line entity and the projected geometry from the plane and select the colinear contraint.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
