Inventor General Discussion
Active Contributor
lemaycj
Message 1 of 4 (151 Views)
constraints
151 Views, 3 Replies
03-20-2012 03:24 PM
I'm working with an assembly and I'm trying to line up the hole from a component with a ref. line (imaginary at this point) as shown on attached jpg.  Which constraint option should I be using?
The .iam is useless without the part files, but your picture is pretty clear.  I think that I would create a workplane through the 45° line and mate the hole axis to that.
Scotty87
Message 2 of 4 (148 Views)
Re: constraints
03-20-2012 03:54 PM in reply to: lemaycj
Looking at the pic, I'd probably do an angular (directed or undirected) assembly constraint set at 45 deg using an origin plane of the shaft and the top face (or an origin plane) of the plate.
JDMather
Message 3 of 4 (139 Views)
Re: constraints
03-20-2012 04:27 PM in reply to: lemaycj
FYI an iam file is only a list of hyperlinks to ipt files and a record of assembly constraints.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Pro
sbixler
Message 4 of 4 (97 Views)
Re: constraints
03-21-2012 04:42 AM in reply to: lemaycj
