Inventor Forum
Constraints deleted but still in giving errors
6 REPLIES 6
Dropjeslover
417 Views, 6 Replies
Hi all,
I've got an assembly where I have some errors. Nothing suprising there, but the constrains that are errorous _do not exist anymore_. See attached screenshot...
Every time I move something or place a new constraint, I get the pop-up.
Removing all (new) constrains and rebuild it (again) does not work.
Using the design doctor to edit, delete or suppres the constraints does not work either.
Inventor 2014.
6 REPLIES 6
JDMather
in reply to: Dropjeslover
Attach the assembly here.
Someone will diagnose the problem and present solution within minutes.
Dropjeslover
in reply to: JDMather
The assembly is very big, in pack&go it would be well over 100mb.
And, it is sort of our company product and such, dunno if I am allowed to share it (as in, quite sure I am not).
JDMather
I think I counted 21 constraints, but up into the 140 numbers?
Sounds like some improvements in assembly techniques could be developed.
Dropjeslover
The assembly has been copied from previous projects and has been rebuilt several times. The assembly with all parts in it has well over 50 constraints in it. That assembly works just fine.
However, when I insert the existing assembly in new (higher level) one and promote the parts I need, the whole thing quite litteraly explodes. When I copy-paste the assembly and then remove the not required parts, I get this problem.
jletcher
Have you tried a rebuild?
 Try this also change to modeling view this will put all constraints in one folder click and look into that folder and see if there are errors in that.
Dropjeslover
As I've said, it has been rebuilt several times and as you can see in the attached screenshot, I'm working in modeling view and can see all constraints with one click.
