Hi all,
I've got an assembly where I have some errors. Nothing suprising there, but the constrains that are errorous _do not exist anymore_. See attached screenshot...
Every time I move something or place a new constraint, I get the pop-up.
Removing all (new) constrains and rebuild it (again) does not work.
Using the design doctor to edit, delete or suppres the constraints does not work either.
Inventor 2014.
Attach the assembly here.
Someone will diagnose the problem and present solution within minutes.
I think I counted 21 constraints, but up into the 140 numbers?
Sounds like some improvements in assembly techniques could be developed.
Have you tried a rebuild?
Try this also change to modeling view this will put all constraints in one folder click and look into that folder and see if there are errors in that.
As I've said, it has been rebuilt several times and as you can see in the attached screenshot, I'm working in modeling view and can see all constraints with one click.
