Inventor General Discussion
Active Member
rjones0215
Message 1 of 8 (234 Views)
Constraint Virus?
234 Views, 7 Replies
05-02-2012 05:35 AM
For 3 or 4 days now, 90% of the time I place a mate or flush constraint, it automatically offsets to some random direction and I have to reset to zero.  Anyone know what might be causing this?
Inventor 2013 Certified Professional
I have never seen this behavior.
Is this with 2013?
Do you have Predict Offset enabled?
Can you attach an assembly here that exhibited this behavior (accept the offset constraint - don't reset it to zero).  Only need the parts that are constrained.
In the constraint dialogue box you have ticked the box with an image of a ruler next to it. When ticked if faces are parallel the dimension they are offset by is automatically placed in the offset box.
Regards
Martin
JDMather
Message 2 of 8 (223 Views)
Re: Constraint Virus?
05-02-2012 05:59 AM in reply to: rjones0215
Is this with 2013?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
Martin_Goodland
Message 3 of 8 (221 Views)
05-02-2012 06:00 AM in reply to: rjones0215
Regards
Martin
PDSU 2014 SP1.3
Windows 7 64bit SP1, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 760GTX Graphics (Diver 337.88)
256GB SSD OS, 80GB SSD working folder
Space Pilot
Employee
johnsonshiue
Message 4 of 8 (211 Views)
05-02-2012 06:08 AM in reply to: rjones0215
Hi! Could you show me an example by providing Inventor files or a video? What release of Inventor are you on?
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Active Member
rjones0215
Message 5 of 8 (209 Views)
05-02-2012 06:10 AM in reply to: rjones0215
Ha.  Yes, I must have clicked the "Predict Offsets" box.  I didn't even know if was there.  It's unchecked now and everything seems to be back to normal.  Thanks again.
JDMather
Message 6 of 8 (197 Views)
05-02-2012 06:55 AM in reply to: rjones0215
Then it should have been 100%  in your original problem description.
Watch out for this one as if your parts are already close to alignment you might not even notice the offset and this is one of the few setting changes that persist after leaving the dialog (I think even after leaving a session of Inventor - but I would have to check on that).
Active Member
rjones0215
Message 7 of 8 (195 Views)
05-02-2012 06:58 AM in reply to: JDMather
I believe you are correct.  In the future, I will be more cautious of this.
Valued Mentor
Martin_Goodland
Message 8 of 8 (177 Views)
05-02-2012 07:36 AM in reply to: rjones0215
It does persist across sessions (I normally have it turned on). It does only work when the mating faces are aligned though, if there is any rotation then the value remains zero.
Regards
Martin
PDSU 2014 SP1.3
Space Pilot
