Inventor General Discussion
Valued Contributor
divingdoug
Message 1 of 11 (2,572 Views)
Constraint mid point to origin
2572 Views, 10 Replies
03-01-2011 07:15 AM
Long time SW user being forced to learn Inventor by corporate machine.
In SW, I could constrain (mate) the midpoint of a line to the origin in two clicks.  I can't even find this option in Inventor.
Anyone know how / if this can be done ?
DivingDoug
divingdoug wrote:
 I am often having to research for solutions to common tasks via tutorials, forums such as these or other training materials.  I rarely had to do that with SW.
Doug
As I teach both CAD programs and I see users with prior experience in one or the other I find users from one or the other saying exactly the same thing in reference to the program they are more familiar with.  These little hurdles that are so easy to clear with experience are maddeningly frustrating when the trick isn't known.
Keep coming back when you hit one of these hurdles and keep an open mind - there is an easy/logical solution, just different.
JDMather
Message 2 of 11 (2,567 Views)
Re: Constraint mid point to origin
03-01-2011 07:22 AM in reply to: divingdoug
DivingDoug
Coincident constraint.  (see attached)
So easy!
You might set up hot keys as decscribed in next post.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
JDMather
Message 3 of 11 (2,567 Views)
03-01-2011 07:23 AM in reply to: divingdoug
DivingDoug
You might start here http://home.pct.edu/~jmather/skillsusa%20university.pdf
JDMather
Message 4 of 11 (2,553 Views)
03-01-2011 07:34 AM in reply to: JDMather
BTW - can you show me how to do it in 2 clicks in SolidWorks?
I can only figure out a minimum of 3 clicks (not counting Ctrl as a click - that would be 4).
Valued Contributor
divingdoug
Message 5 of 11 (2,540 Views)
03-01-2011 07:52 AM in reply to: divingdoug
OK, in SW, 2 clicks assumes one entity is alread selected.
Was able to make the line coincident with the origin (had to turn off the coordinate system indicator before I was able to select the origin)
Was not able however to make it coincident to the midpoint of the line.
Looked through the tutorial and found a few things I had missed in trying to optimize my setup but nothing about midpoints.
JDMather
Message 6 of 11 (2,536 Views)
03-01-2011 07:56 AM in reply to: divingdoug
What is the coordinate system indicator - I never used that?
Attach the file here - it should be trivial easy - select the midpoint, not the line as in SolidWorks - see the video I attached earlier.
Valued Contributor
divingdoug
Message 7 of 11 (2,531 Views)
03-01-2011 08:07 AM in reply to: divingdoug
Attached a pic of the coord system indicator, will fix my template for that item
Also attached part file.  Working to make a standard aluminum extrusion part.  Yes, these are downloadable from many vendors but I have yet to find one that has it in native Inventor format and I when I use these, I need for the part to be parametric.
Still looking and still cannot find a midpoint to select.
Valued Contributor
Loren_J
Message 8 of 11 (2,525 Views)
03-01-2011 08:15 AM in reply to: divingdoug
I want to reinforce JD's suggestion to go through his tutorials. I have a lot of respect for his knowledge, and it is great that he shares his tutorials with the CAD community. The Inventor tutorials are actually pretty decent.
After you start the Coincident constraint tool, mouse along the line. When the pointer hits the midpoint, a green dot displays.
There are different highligthing cues, depending on the pointer position.
  • The Green dot displays when you hover over the midpoint of a line.
  • Other points change color and/or size.
Also, there are two ways to start the Coincident constraint. You can select it from the ribbon, or you can right click and go to Create Constraint>Coincident. You should try to take advantage of the rich context menus in Inventor.Whenever I train somene, I keep telling them to right-click. It is significantlyfaster than mousing to a ribbon or toolbar, and it reduces mouse motion.
I want to reinforce JD's suggestion to go through his tutorials. I have a lot of respect for his knowledge, and it is great that he shares his tutorials with the CAD community. You should also use the Inventor tutorials. They are actually pretty decent.
LorenJ
LorenJ
Inventor 2011 Pro
Win7 64 SP1
Xeon W3550 @3.07 GHz
ATI FirePro V5700, 8.773.0.0
12 GB RAM
Valued Contributor
divingdoug
Message 9 of 11 (2,503 Views)
03-01-2011 08:39 AM in reply to: divingdoug
That got it !
I didn't think I was being deprecating on JD's input or the tutorials he suggested. Indeed, I did run through the first one he posted the link to and have saved it to my local drive for reference.
As I proceed through the trials of learning Inventor however, I simply find it much less intuitive than SW. I am often having to research for solutions to common tasks via tutorials, forums such as these or other training materials.  I rarely had to do that with SW.
As I proceed, I am sure I will continue to utilze this forum as in my environment, I have to find the quickest path to a solution, and going through at tutorial to locate an answer to a single issue can take more time than I have.
Thanks for the help on this
Doug
JDMather
Message 10 of 11 (2,500 Views)
03-01-2011 08:46 AM in reply to: divingdoug
Doug
