Has anyone run into this. I have an assembly, that every constraint I place brings up the can't be solved dialog, but if I accept the relationship, and then drag the part it jumps into place and the constraint is happy. Every single constraint I place is like this.
I can't post the files here, but if Autodesk is interested (if it isn't just something I have accidently switched on or off) I can send it to them.
In your Application Options under the Assembly tab... do you have Defer Updates checked?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi KentKeller,
In addition to cbenner's suggestion, I think I recall resolving something like this in the past by going to the Manage tab > Rebuild All button. If I recall correctly the rebuild forced the actual issue to the top so that I could fix it, and then everything was good after that.
I hope this helps.
Curtis
