Inventor General Discussion
Distinguished Contributor
cadcamm99
Message 1 of 10 (312 Views)
Constraint Dots
312 Views, 9 Replies
09-13-2012 09:59 AM
I have Inventor 2012.  When I work on a new model, I have the Yellow and Green dots when sketching.
However if I work on an older model, the dots do not appear.  I have everything on. See attachments.  Not sure what else to check.
Distinguished Mentor
john.retzlaff
Message 2 of 10 (297 Views)
Re: Constraint Dots
09-13-2012 10:53 AM in reply to: cadcamm99
On an existing sketch you will have to use show constraints to see the conincident constraints (yellow boxes).
John Retzlaff
cbenner
Message 3 of 10 (289 Views)
Re: Constraint Dots
09-13-2012 10:59 AM in reply to: john.retzlaff
Quick key to show Constraints is F8, just for reference.... F9 turns them off.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
cadcamm99
Message 4 of 10 (281 Views)
Re: Constraint Dots
09-13-2012 11:10 AM in reply to: cbenner
Actually didn't mean the grips.  I meant the yellow dot that follows the cursor and the green dot that shows up when your cursor is on an end point, midpoint or intersection point.
mrattray
Message 5 of 10 (262 Views)
Re: Constraint Dots
09-13-2012 12:26 PM in reply to: cadcamm99
Mike (not Matt) Rattray
*Pro
ampster
Message 6 of 10 (254 Views)
Re: Constraint Dots
09-13-2012 12:30 PM in reply to: mrattray
OP's first pic shows those already set.
Just a guess since you mentioned older files, is it possible these files have not been fully migrated or saved up to the latest version you are using?
cadcamm99
Message 7 of 10 (244 Views)
Re: Constraint Dots
09-13-2012 12:35 PM in reply to: cadcamm99
Turns out it is my part that is causing the problem.  After leaving Inventor and going back into it, things went back to normal.  However the more I worked with the part, it became progressivly unstable.  Not sure why part is doing that.
*Pro
ampster
Message 8 of 10 (239 Views)
Re: Constraint Dots
09-13-2012 12:37 PM in reply to: cadcamm99
if possible, post your file/s here for others to look over.
I don't have 2012 myself, still on 2011 but maybe someone else can take a peek into your model and prehaps find something odd in there.
mrattray
Message 9 of 10 (234 Views)
Re: Constraint Dots
09-13-2012 12:49 PM in reply to: ampster
Oops, missed that.
john.retzlaff
Message 10 of 10 (231 Views)
Re: Constraint Dots
09-13-2012 01:00 PM in reply to: cadcamm99
Have you done a rebuild on the part?
John Retzlaff
