Inventor Forum
Constraint - Ball bearing to hole??
7 REPLIES 7
Message 1 of 8
1365 Views, 7 Replies
I am trying to constrain a ball bearing and a small hole. The hole is smaller then the ball bearing. The bearing rest on the lip on the hole (Seals hole). How do I or can I constrain it in this manner??
thanks,
7 REPLIES 7
Message 2 of 8
An insert should work fine.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
manner??
thanks,
Message 3 of 8
The bearing should rest tangent to the hole... partly below the holes top surface. I don't believe that Insert will work. And if it did, wouldn't that place the ball inside the hole or above (Not seal). In addition, the insert constraint won't allow me to select the ball bearing.
Message 4 of 8
Message 5 of 8
You didn't mention anything about it being
tangent.  Can you post an example in iCF.  I'm not following what you
want to do.
Sean Dotson, PE
Check the Inventor
The
Message 6 of 8
How about the TANGENT constraint?
Rui
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">The
Message 7 of 8
There is a ball bearing in a countersunk hole with a spring behind it, which forces it to seal a smaller fluid passage hole.
See CF for example.
Thanks for any assistance!
Message 8 of 8
Use the ball axis and a plane in the ball bearing.
Mate the ball axis to the hole.
Mate the ball plane to the face with and offset above the part.
Drive the face and plane mate with collison detection.
The ball should stop when it hit the edge of the hole.
