Inventor General Discussion
Active Member
kenevens93
Message 1 of 11 (352 Views)
Constraining to a random path
352 Views, 10 Replies
10-22-2012 10:19 AM
My goal is to let some wheels roll in a path which excist from 2 straight paths and a corner.
I can constrain them to 1 path at a time but not to all of them so my wheel makes a corner. I
You can find the guiderail as attachment. There is a path in the sketch from which i sweeped my form but he divides it in the 3 parts so i can't constrain the center point of my wheel to this path...
Can someone help me and give me some help.
Thanks a lot
JDMather
Message 2 of 11 (338 Views)
Re: Constraining to a random path
10-22-2012 11:48 AM in reply to: kenevens93
kenevens93 wrote:
....divides it in the 3 parts so i can't constrain the center point of my wheel to this path...
Use Transitional constraint - not tangent.
I didn't see a wheel part file or an assembly file to demonstrate.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
kenevens93
Message 3 of 11 (333 Views)
10-22-2012 11:58 AM in reply to: JDMather
this is a wheel. But there need to beseveral wheels roll in this guide rail an they are attached to each other by a steel cable (the test assembly is without the attachement).
I've tried to work with the transitional but when all the wheels were constrained, he gave an error so nothing could move anymore..
Thanks for the fast reply
JDMather
Message 4 of 11 (314 Views)
10-22-2012 04:32 PM in reply to: kenevens93
You will need to add assembly constraints.
"when all the wheels were constrained"
I don't see any constraints.
Active Member
kenevens93
Message 5 of 11 (284 Views)
10-23-2012 09:07 AM in reply to: JDMather
This is a test part of my full project so far. The names are in Dutch but you'll understand it right away because it's quite easy.
My problem is still the same. Letting the wheels roll inside the guide rail. There are only 2 now but in the end there will be 8 at each side so multiple panels can move like a sectional port at your garage.
Thanks by advance for your time.
JDMather
Message 6 of 11 (238 Views)
10-24-2012 10:02 AM in reply to: kenevens93
The track isn't grounded.
The wheels aren't constrained to the track.
A continuous surface can ge created through a trick of Delete face and then Patch (Boundary Patch).
But I think I would use Dynamic Simulation enviroment for this instead (works much better for motion like this).
To continue a discussion simply respond - bump.
JDMather
Message 7 of 11 (235 Views)
10-24-2012 10:04 AM in reply to: JDMather
To solve the problem - I recommend you concentrate on one panel at a time.  After you get the first one working (in DS) the rest will be easy.
JDMather
Message 8 of 11 (225 Views)
10-24-2012 10:14 AM in reply to: JDMather
There is no clearance between the wheels and the guidrail - both are 50mm?
Active Member
kenevens93
Message 9 of 11 (221 Views)
10-24-2012 10:17 AM in reply to: kenevens93
Yeah, I would normally change that but i first wont to know that its works like this
JDMather
Message 10 of 11 (217 Views)
10-24-2012 10:32 AM in reply to: kenevens93
Here is a trick to create a continuous surface with no seams.
