How does one constrain a sketched lin in the sketcher to a datum plane?
Solved by JDMather. Go to Solution.
Use Project Geometry in the sketcher, select the datum plane. That brings it in to your sketch. Then constrain your sketch lines to it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Being new to Inventor, what do you mean by "Project Geometry" are you talking about construction lines?
My thinking is that I should be able to select my construction line or center line then select the plane and hit coincident
and the two snap together, but that is not what happens.
While in sketch mode there is a Project Geometry icon (have you used other parametric software like SWx or Pro/E so that I can use similar terms to those).
Inventor is not aware of any geometry that hasn't been created by you in the sketch or projected into the sketch.
You might read this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
Sorry, I had a screenshot... I posted it in your other thread, since the topic was similar.
Thanks JD.
Chris Benner
Yes, I am very familiar with Solidworks.
I am generally struggling with how the contraints work in Inventor.
I get them to work sometimes and not at other times.
In Solidworks I am used to creating construction or centerlines
then selecting the ones you want constrained and selecting the constraint
and the two snap together.
