Inventor General Discussion
Distinguished Contributor
1 Kudo
Post 1 of 3
Constraining a peg to a groove
225 Views, 2 Replies
06-05-2012 08:18 AM
I have to constrain a peg to a groove to allow it to move guided by it.  The groove is made with a sweep of a rectangle guided by a path made of straight lines and arcs.  I am only able to constrain the peg to either the straight portions or the arc portions of the groove but not to the complete groove.  Is there any way to allow the peg to slide along the entire groove?
2,126 Kudos
Post 2 of 3
Re: Constraining a peg to a groove
06-05-2012 08:29 AM in reply to: elmotors
Transistional Constraint.
Attach your assembly here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
1,703 Kudos
Post 3 of 3
06-05-2012 01:17 PM in reply to: elmotors
Hi elmotors,
As JDMather said, you'll want to use a Transistional Constraint. Attached is simple example  to reference.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
