Only in MDT. I'd guess there is a system configuration problem that's
making it crash: some other program that's running (maybe even OE; I've
taken to running with mine off) or a TSR or Anti-Virus or a budget ram
problem ... something conflicting, but you'll just have to run it down; too
many possibilities.
~Larry
"Kevin Wehner" wrote in message
news:4BC040EEFB44B3FA20E49820E9D588EC@in.WebX.maYIadrTaRb...
> If I do that, it crashes. Is there something similar to MDTs audit or
> amrecover?
> Kevin Wehner
> 724.941.9704-3019
> SKC Inc.
> 863 Valley View Road
> Eighty-Four, PA 15330
> "Larry Caldwell" wrote in message
> news:8538057CF8625DB7A1405F7455552B91@in.WebX.maYIadrTaRb...
> > Instead of axis, you can select other to select the tapered faces (the
cl
> > turns off) and use the mate command or you can use insert by
highlighting
> > the circles at one or another intersection.
> > ~Larry
> > news:8F07EA5C87B35C4FC301835A6D82AFE8@in.WebX.maYIadrTaRb...
> > > I'm trying to constrain a flat head screw to a countersunk hole. In
MDT
> I
> > > would use insert and select the tapered face on both parts. I
apparently
> > > can't do that here. If I try to mate the axis of the screw to the axis
> of
> > > the hole and then mate the two tapered faces, IV crashes everytime.
This
> > > can't really be that difficult. Am I missing something?
> > > Kevin Wehner
> > > 724.941.9704-3019
> > > SKC Inc.
