"dwpbemis" <I
href="mailto:dwpeterson@bemis.com">dwpeterson@bemis.com> schrieb im
Newsbeitrag
href="news:f14f252.-1@WebX.maYIadrTaRb">news:f14f252.-1@WebX.maYIadrTaRb...
am trying to constrain a camshaft and can only get it to work partially. The
cam is rotating and it needs to move a pushrod up and down much like a pushrod
for a valve assembly in an engine. When I choose transitional constraint, it
will only let me choose one of the cam's surfaces. It follows that one face,
but stops when the radius of the cam changes. I would like it to go up and
down and follow the entire outer surface of the cam. I've had no luck, any
advice is appreciated...thanks.
"W. Holzwarth" <
href="mailto:wh@holzwarth-cad.de">wh@holzwarth-cad.de> wrote in message
href="news:886A62D73035FF989F7F3F0EC2218DFF@in.WebX.maYIadrTaRb">news:886A62D73035FF989F7F3F0EC22......
I've struggled some time with a crankshaft cam of
a 4-stroke model engine, that didn't drive by constraint. Meanwhile I've
detected my fault:
The moving contours are critical. You must avoid
point contact, or edge pressure between the moving surfaces.
I've put a moving example to CF. It can be driven
with KW-Drehung of part YS2620.
Now change Fillet1 of YS0675 to 0.5mm. It refuses
to move the whole way. The reason is, that the contact area moves thus to the
edge of the cylinder of YS0675.
Same influence can be seen by changing the
contact zone of YS2660.
Regards
Walter
"dwpbemis" <I
Newsbeitrag
pushrod for a valve assembly in an engine. When I choose transitional
constraint, it will only let me choose one of the cam's surfaces. It follows
that one face, but stops when the radius of the cam changes. I would like it
to go up and down and follow the entire outer surface of the cam. I've had
no luck, any advice is
"Laurence Yeandle" <
href="mailto:laurenceyeandle@supanet.com">laurenceyeandle@supanet.com>
schrieb im Newsbeitrag
href="news:D7F8ED6B6DE287B601427D67803D64E4@in.WebX.maYIadrTaRb">news:D7F8ED6B6DE287B601427D67803......
I only see failures of the transitional
constraint on your file? If the cam followers were radiused then it would work
fine.
Laurence,
Power is nothing without
Control
"W. Holzwarth" <
message
href="news:886A62D73035FF989F7F3F0EC2218DFF@in.WebX.maYIadrTaRb">news:886A62D73035FF989F7F3F0EC......
of a 4-stroke model engine, that didn't drive by constraint. Meanwhile I've
detected my fault:
avoid point contact, or edge pressure between the moving surfaces.
driven with KW-Drehung of part YS2620.
refuses to move the whole way. The reason is, that the contact area moves
thus to the edge of the cylinder of YS0675.
Regards
Walter
"dwpbemis" <I
Newsbeitrag
The cam is rotating and it needs to move a pushrod up and down much like a
follows that one face, but stops when the radius of the cam changes. I
would like it to go up and down and follow the entire outer surface of the
cam. I've had no luck, any advice is
"W. Holzwarth" <
href="news:658916649827DDB5042A3D11C81CBBB9@in.WebX.maYIadrTaRb">news:658916649827DDB5042A3D11C81......
Hmm, Laurence
I've realized, that it's not moving with
my IV6 SP2. But I've seen it moving...
Where? I'm not allowed to talk about ...
Walter
href="news:D7F8ED6B6DE287B601427D67803D64E4@in.WebX.maYIadrTaRb">news:D7F8ED6B6DE287B601427D678......
work fine.
Laurence,
Control
"W. Holzwarth" <
message
href="news:886A62D73035FF989F7F3F0EC2218DFF@in.WebX.maYIadrTaRb">news:886A62D73035FF989F7F3F0......
cam of a 4-stroke model engine, that didn't drive by constraint. Meanwhile
I've detected my fault:
Regards
Walter
"dwpbemis" <I
im Newsbeitrag
a pushrod for a valve assembly in an engine. When I choose transitional
the cam. I've had no luck, any advice is
