Inventor Forum
Constraining a 2 jaw gripper
10 REPLIES 10
Message 1 of 11
albmopar
718 Views, 10 Replies
Is there a way to have a 2-jaw parallel gripper's jaws move in synch?  That is when I move 1 jaw the other one moves the same distance.
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: albmopar
Yes.
Attach your assembly here.
What book are you using to learn Inventor?
Message 3 of 11
albmopar
in reply to: JDMather
What makes you think I am using a book?  Can't an educated guy ask a question?
Message 4 of 11
JDMather
Part #
MHF2-12DR-M9BWSAPC_2
appears to me to be the same as
MHF2-12DR-M9BWSAPC_3
is there any physical difference between these parts?
Message 5 of 11
albmopar
That is how the model comes in.  Same part, 2 instances.
Message 6 of 11
JDMather
Looked like 2 parts, one instance each to me.
Try the attached.
You can drag the seed or right mouse button and Drive Constraint on the "Drive This".
I didn't take the time to set up Open/Closed Position Reps with this arrangement.
Message 7 of 11
albmopar
Message 8 of 11
JDMather
...you could also do with the 2 parts, I just thought this was easier.
Message 9 of 11
albmopar
How?
Message 10 of 11
karthur1
I know you have this marked as solved, but another way to do this is to use the new "Symmetry" contraint.  I used the midplane of the base block as the center plane.
Now when you drag one (or set an offset distance).... the other moves the same amount.
Kirk
Message 11 of 11
JDMather
in reply to: karthur1
Forgot (or maybe didn't even know) there was a symmetry constraint now.
(I took the liberty of marking your suggestion as the solution.)
