Is there any kind of pattern to the parts?
How many parts?
Can you attach screen capture image?
Assembly constraints are set up to be applied one part at a time. The only option would be if there was iMates assigned to each component and when used and the part is placed in a file it would automatically align. But No you can’t do multiple components with one constraint.
constraints are maintained now between copied parts..
Maybe you set 1 leg with its places then copy the leg/plate
Or pattern the leg component.
Thanks!
Thanks everyone for your inputs. I figured out what I was doing and have got all the parts constrained now. It was just a matter of not over thinking everything, and with the idea to use the patterns it made it a snap.
Again thanks to everyone.
Keith
