Sounds like two coils and a straight extrusion to me, assuming you want to model the actual spring blade. Is there some reason a pair of disks and a thin blade between won't suffice?
Not sure if that would work for a positional representation...I could model the spring like that for the closed position and just turn it off for the open position I guess.
Would probably have to be turned off for any animations too.
Spiral Coil a line as a surface and then Thicken.
add additional sketch geometry as needed. Animate Parameter for motion of spring. (give a parameter name to the Pitch as well so that it can be animated)
You didn't indicate Inventor version - or I could have posted an example ipt file.
Image shows Studio increase Pitch between 0 and 1 sec, decrease pitch between 1 and 2 sec.
Hey,
I am also trying to build a constant force spring on either Autocad, Solidworks or Catia and also simulate the dischrage of that spring after a full winding. Could any one help with instructions or any kind of tutorials? Thanks
Hi
You can watch video
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
örneğin etiket rulosunun bir kasnak etrafında sarılı iken düz bir yol izleyerek çözülme montajını nasıl yaparım?
Hello
you can see this video https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/screencast/Main/Details/...
Merhaba Yalcın bey
linkteki video size yardımcı olabilir bir deneyin
Gökhan Kaya
Tehcnical Manager
LinkedIn
