Inventor Forum
CONICAL SPRING
11 REPLIES 11
Message 1 of 12
camilorivera8311
3301 Views, 11 Replies
CONICAL SPRING
On the module generating inventor springs 2012 can generate aconical spring?  Someone could tell me how. Thanks
11 REPLIES 11
Message 2 of 12
JDMather
in reply to: camilorivera8311
Are you referring to the Design Acclerator in the assembly environment or simply adding a taper angle in the part environment with the Coil feature?
Message 3 of 12
camilorivera8311
in reply to: JDMather
I'm referring to the Design Acclerator in the assembly environment. Thanks
Message 4 of 12
JDMather
I don't think there is a way to do it with the DA.
Message 5 of 12
camilorivera8311
This is the problem. I am not sure, so the calculation?.
Message 6 of 12
Try the Content Center > Fasteners > Washers > Spring
Mike
Message 7 of 12
Mike_Maenpaa
in reply to: Mike_Maenpaa
Or the Belleville Spring Generator.
Mike
Message 8 of 12
JDMather
Something like this?
More informatioin is needed.
Message 9 of 12
camilorivera8311
Yes, just like that is what I need, but enabled to perform calculations on it.
Thanks.
Message 10 of 12
Good Afternoon. This is the answer that give me the Autodesk specialist. Thanks for your colaborations.
"Dear Camilo Rivera
 Thank you for contacting Autodesk Support.Your observation is correct, the module Inventor Design Accelerator does not support the creation of conical springs, springs can only be created straight through the tool."
Message 11 of 12
tonynarducci
"Accept as Solution"  i'm using inventor.  wire dia .055", oal= 1.705", od @ top = .630", od @ bottom = .725".
can you help?
Message 12 of 12
JDMather
in reply to: tonynarducci
Use the Coil feature.
Attach here what you have attempted so far.
