Yet another thread on Content Center Not working (sorry) Quick answer - IMHO - INV19101 causes the Problem it was tring to fix!
I thought I would share an issue I ran into. User came to me Friday telling me "Place from Content Center" was not working. We have just gone Live with 2015 on this past Monday. All was good through 2 month trial.
All the solutions for fixing this issue were tried (reboot server, non admin, install/active....)
Symptom: “Place from CC” does not produce the CC Popup.
“Configure Content Center” does not produce the expected Popup
Problem effected ALL Users – “Place from CC” and "Configure Content Center" worked at least up till Wednesday afternoon. Wednesday SP1 and INV19101 were installed on all users stations.
Diagnostics1:
On a workstation with latest SP and updates (SP1 & INV19101)
1) Fresh user login after power cycle/reboot
2) Open PDSU Inventor 2015
3) Click Projects Icon
4) Verify “15 Vault” Project file selected (location d:\)
5) Click “Configure Content Center” Icon
6) Login to Vault Popup appears – Login into vault with known account
7) No further Popup for Configuring Content Center appears
😎 Clicking “Configure Content Center” produces the same results – NOTHING
Diagnostics2:
3) Click Tools
4) Click on Application Options
a) Click on Content Center Tab
Change “Autodesk Vault Server” Radio Button to “Inventor Desktop Content”
b) Click Apply and Close
5) Exit PDSU Inventor 2015
6) Restart Inventor
7) Re-Test as In Diagnostic 1
You should see your Local version of CC.
Now - Repeat steps 1-4 changing radio button back to “Autodesk Vault Server”
If INV19101 (9/17/14 version) is installed - you may see an Inventor Crash - When you click apply/close
Solution:
Remove INV19101 via Windows Add/remove and retest. Thank-you M2 Technologies &AutoDesk for this solution!
I am not sure what could have caused this to not function anymore. I am curious if the Inventor registry information may have been suspect. Here is a link to a reset utility that might be worth trying first if this pops up again.
Don
