With respect to hatch patterns, I assume that Walt got you going down the
right path.
With respect to the materials themselves, the materials we ship are
basically just examples. The material style is pretty flexible, go ahead
and set up your own. You probably know the concrete specs better than I do,
but you might try these resources:
http://www.matweb.com/index.asp
http://www.efunda.com/home.cfm
Honestly, I'm surprised that one of your web-savvy peers (Kent or Sean or
Charles), hasn't provided a sharing mechanism for materials (and other
styles) since the R9 styles overhaul. XML makes them pretty portable.
Maybe somebody already has, and I'm just not looking in the right places.
Hope that helps,
Andrew Faix
Product Designer - Inventor Drawing Manager
wrote in message news:5199624@discussion.autodesk.com...
Does anyone know if Autodesk has done anything to create a concrete
material? What about a concrete hatch pattern?
(I requested this over 2 years ago and thought I would check in to see if
anything has been done.)
