Inventor Forum
Concrete mass Properties
11 REPLIES 11
Message 1 of 12
523 Views, 11 Replies
I need to find the mass properties of concrete, weight (g/cm^3) anyone have
this info and would be willing to share? I have found only one number. and I
would like to finish the rest.
Jerry
11 REPLIES 11
Message 2 of 12
Problem is, concrete is a composite. So it varies depending on who makes it i guess. Its a bit like a question on here ages ago asking for the weight of carbon fibre, you cant tell unless u have more information on it. But you could try looking up a concrete company and seeing that they say.
Message 3 of 12
Sure, I realize that it isn't a constant, I just
wanted a number. I have done the weight and this is all I need for the moment. I
came up with 2.1945 g/cm^3 this is 137 lb/ft^3 found it in the machinery
handbook.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Problem
say.
Message 4 of 12
Guy down at the concrete factory says about 2 ton per cubic
yard.
Have a nice day
I came up with 2.1945 g/cm^3 this is 137 lb/ft^3 found it in the machinery
handbook.
Problem
say.
Message 5 of 12
See ICF - from Weight Engineers Handbook 1976
Message 6 of 12
That's interesting. I was estimating that it would be about 80% if the weight of granite. That comes out to 138 lb/ft^3.
Tom
Message 7 of 12
xavierl
according to BS882 weight of concrete for structural design purposes is to be taken as 23.6kN/m3(2.4057g/cm3)
compressive strength fcu=20N/mm2, Static Modulus Ec=25GPa
fcu=30N/mm2, Ec=28GPa
fcu=40N/mm2, Ec=31GPa
SI metric is the way , not slugs/square furlong...
Frans X Liebenberg
Message 8 of 12
A good estimate for normal weight 3000 psi concrete
is 145 pcf and 150 pcf if it is reinforced.
That's
Tom
Message 9 of 12
Does that book have a copyright notice? People please don't post copyrighted material !!
I have removed the post from IVCF.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"bobuhl" wrote in message
news:f19b45f.3@WebX.maYIadrTaRb...
Message 10 of 12
Jerry,
Just get a chunk of concrete and do a "specific gravity" check. (Density = SG).
What... dont know how to do SG check ya say... Check here.
http://www.ganoksin.com/borisat/nenam/gravity.htm
and here
http://www.engineeringtoolbox.com/24_290.html
and if ya want to get really technical try this...
http://www1.coe.neu.edu/~ozgu/exp3.pdf
Don A 🙂
Don A 🙂
Message 11 of 12
2 different values depending on composition/strength
2.2 = 0.079 ( lbmass/( in^3 ) )
2.4 = 0.087 ( lbmass/( in^3 ) )
>Jerry
Dennis Jeffrey
Autodesk Product Consulting and Training
Center for Design Excellence
http://www.engineering-helpdesk.com
http://www.design-excellence.com
260-459-1311 ext 221 or 800-550-6070 ext 221
Message 12 of 12
concrete (reinforced): 2.381 g/cm3
