Inventor General Discussion
CCrabtree1
Message 1 of 12 (304 Views)
Concave rack
304 Views, 11 Replies
06-03-2013 10:06 AM
I need to make a rack for a machine I am designing.  We use a variation of this now but I need to change the rack we have always used.  The rack is on a radius and the teeth are on the inside of said radius.  I plan on using the same tooth profile that we are currently using but i was wondering if there was an easy way to pattern this.  Any ideas or suggestions will be greatly appreciated.  Thanks in advance.
Windows 7 64 bit
16 GB ram
Intel i7 2600 3.4 ghz
AMD radeon HD 6450
PDSU 2013
Distinguished Mentor
rdyson
Message 2 of 12 (292 Views)
Re: Concave rack
06-03-2013 11:24 AM in reply to: CCrabtree1
A curved rack is a gear, in your case an internal gear. The teeth on a rack are trapizoids, on a gear they are somewhat more compicated.
Depending on your requirements the trapizoidal teeht might be acceptable. Without more information, we can't give any advice.
CCrabtree1
Message 3 of 12 (284 Views)
Re: Concave rack
06-03-2013 12:06 PM in reply to: rdyson
Thanks for your reply rdyson.  I am attaching the "print" I am starting with.  I don't know how much its going to change but I thought I would do a little prework before it gets dumped on my lap.  The is attached to a base plate and then a Marin S312  drive gear on a gearbox moves the machine around a pivot.
thanks again
Windows 7 64 bit
16 GB ram
AMD radeon HD 6450
PDSU 2013
*Expert Elite*
blair
Message 4 of 12 (282 Views)
Re: Concave rack
06-03-2013 12:10 PM in reply to: CCrabtree1
I might look at a Planetary gear assemby and only use a portion of the outer gear ring.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
CCrabtree1
Message 5 of 12 (277 Views)
Re: Concave rack
06-03-2013 12:22 PM in reply to: blair
blair, could you elaborate a bit more.
thanks
Windows 7 64 bit
16 GB ram
AMD radeon HD 6450
PDSU 2013
rdyson
Message 6 of 12 (267 Views)
Re: Concave rack
06-03-2013 01:09 PM in reply to: CCrabtree1
The info I'm talking about is like speed, torque, cycles, etc
*Expert Elite*
blair
Message 7 of 12 (262 Views)
Re: Concave rack
06-03-2013 01:18 PM in reply to: CCrabtree1
A curved rack, rather than a linear rack could be described as a Planetary Gear set but with only a single spur gear and a ring gear. All you need is a portion of the ring gear. All the gear teeth profile data is easily accesable for these gear sets.
Win7-64
Delta Tau Chi ΔΤΧ
*Expert Elite*
JDMather
Message 8 of 12 (257 Views)
Re: Concave rack
06-03-2013 01:38 PM in reply to: CCrabtree1
Circular Pattern feature?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
CCrabtree1
Message 9 of 12 (196 Views)
Re: Concave rack
06-05-2013 08:18 AM in reply to: JDMather
I appreciate all your input guys.  Let me respond to a couple of these: rdyson, the speed and cycles are non factors, the speed is very slow and the the cycle is only every so often when the operator makes the machine pivot so it could be once an hour or once a week, but either way not anything that could be considered a cycle and I can't really figure the torque right now without it being a guess becasue this machine is still in development.  blair, great idea about finding the Planetary gear set but the problem I am having with that is I cannot find a set that even comes close to the parameters I know.  JDMather, I would love to use the circular feature for this but as I stated in the answer to blair, this rack and pinion seems to be custom so finding just the right value to make everything come out right is eluding me.  A straight rack is simple and is logical, the what seems to be a custom rack on a radius is making me crazy.  Thanks again for all the help.  I apoligize for my ignorance also  :smileyhappy:
Windows 7 64 bit
16 GB ram
AMD radeon HD 6450
PDSU 2013
*Expert Elite*
blair
Message 10 of 12 (193 Views)
Re: Concave rack
06-05-2013 08:28 AM in reply to: CCrabtree1
A good gear book or possibly the Machinist Handbook will provide the data required. I would model the single tooth profile on the curved rack at one end and then as JD mentioned, pattern it to create the remainder of the teeth.
Win7-64
Delta Tau Chi ΔΤΧ
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
