Inventor General Discussion
Distinguished Mentor
rdyson
Message 11 of 12 (89 Views)
Re: Concave rack
06-05-2013 08:53 AM in reply to: CCrabtree1
Given your speed and cycles, trapezoidal teeth might be okay. You will incur wear on either the gear or the 'rack' teeth (depending on which is softer) but it might be acceptable since it will not require repair often enough to be a bother.
Per JD, model the curved bit, add a trapezoid tooth and pattern it the appropriate distance around the curve.
CCrabtree1
Message 12 of 12 (68 Views)
Re: Concave rack
06-07-2013 04:12 AM in reply to: rdyson
Well I appreciate all the advise guys.  I am attaching my finished product.  I decieded to do it as an assembly just to make it easily adjustable if need be.  It was a little time consuming but now if i need to change it or adapt it to another radius it will be rather easy.  Thanks again.
Windows 7 64 bit
16 GB ram
Intel i7 2600 3.4 ghz
AMD radeon HD 6450
PDSU 2013
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
