So, I just became a part of the Student Community here, and downloaded Inventor Pro. I actually had some problems right off the bat: some kb971153 file was missing, so I had to find a hotfix from MS and install it before it would let me install Inventor.
Anyway, I opened up Inventor, and found that within seconds of loading up a new .ipt file, my computer would freeze. I can confirm that ctrl+alt+del, mashing several other buttons in frustration, and thinking of creative ways to use four-letter words to describe the situation don't work. As far as I can tell, .dwg files work just fine, it's just the .ipt ones that are kick my blood pressure up a notch.
If I remember correctly, the hotfix had to do with individual licensing or something, so it shouldn't be the cause right? Everything else on the computer works just fine; if I downloaded the wrong fix or something, I figure I'd see some problems with the computer overall. So I'm lost. Maybe it has to do with the stuff the .ipt file is trying to load or access but, either way, it's causing me to have to turn my computer via power button, something I'd rather avoid.
Am I doomed to never live life in 3D? I turn to you, Autodesk community, in my darkest hour. Well, not quite, but it's still an annoying problem.
Solved by johnsonshiue. Go to Solution.
More system & version information would help.
Did you follow all the installation prerequisites?
Recommended install instructions:
http://teknigroup.com/support/InstallAdsksoftware.html
System informatin helps:
@Anonymous wrote:Recommended install instructions:
http://teknigroup.com/support/Inventor/Howto.html
@Anonymous 'bout that. I'm running Windows Vista Home Premium (64-bit) SP2 on a computer with an Intel Core 2 Duo T6600 @ 2.2GHz, 4GB RAM, 500GB HDD, and an ATI Mobility Radeon HD 4570 graphics card. Excel, Flash, and Internet Explorer all meet the specs. My antivirus software is Avast version 110642-0. The problem occurs regardless of what programs I have open- once I had Google Chrome open alongside Inventor 2012 and the other time, I had nothing else open.
Since I'm running Vista, I had to use Microsoft Vista Hotfix KB971138 in order to install the software. I hope I installed the right one, otherwise I guess that would be an issue. I hope the graphics card is adequate, because replacing it will be a little tough on a laptop.
The first time it froze, I went into the standard.ipt type file and just drew a rectangle. The second time, I clicked one of the commands - trim I think, I can't remember for sure - and it froze. After the usual ctrl+alt+del, I just left it alone, but it never "unfroze" (thawed, I guess). The computer doesn't experience issues ofany kind otherwise.
Hi! The Vista hot fix KB971138 is a must to install Inventor R2012. The crashing behavior you are seeing is likely graphcis related. I suspect the graphics card might not have enough memory processing Inventor graphics. Could you try making the following change and see if it works better for you?
Start Inventor.
Go to Tools -> Application Options -> Hardware -> select Compatibility and check Software graphics option.
Thanks!
@johnsonshiue wrote:Hi! The Vista hot fix KB971138 is a must to install Inventor R2012. The crashing behavior you are seeing is likely graphcis related. I suspect the graphics card might not have enough memory processing Inventor graphics. Could you try making the following change and see if it works better for you?
Start Inventor.
Thanks!
Yep, it looks like you're right. I put it in Compatibility mode and checked Software Graphics as well, and now the program isn't crashing anymore. But I did just get an error message: "trying to allocate 96 bytes". And now that I'm able to use the program a little, it's apparent that there's quite a bit of slowdown. Do you think an older version of Inventor, like Inventor 2010 would work better? It's not a necessity that I use 2012, I just figured I'd get the latest and greatest (without checking recommended specs) as long as I was going to be downloading the software.
And thanks to both of you for your help! I've never posted in a community like this, so I wasn't sure what to expect.
Hi! You can try and see if R2010 works better on your machine. But, clearly the behavior you are seeing indicates the hardware (graphics card/memory/CPU) you have may not be optimized to run Inventor.
Thanks!
Ah! I exit the startup box to be able to access the "tools" and it still shuts down! Extremely Frustrating!
You would be better off starting a new post/thread and not one that is 1 1/2 years old and has been flagged as solved.
System information/spec's would be nice, version of Inventor would help. If this is a new installation, did you follow all the prerequisites, Admin privileges, UAC slider set to lowest setting.
Are you opening the file from within the Inventor open-file dialogue box?
