Inventor Forum
compression spring
4 REPLIES 4
chris31
1015 Views, 4 Replies
compression spring
Is there a way to extract the data used to design a compression spring in the design accelerator? Inv 2013 Thx! Chris
4 REPLIES 4
JDMather
in reply to: chris31
Not exactly sure what information you are after, but -
Open the ipt file and switch from Assembly View to Modeling view.
chris31
in reply to: JDMather
We're trying to extract things like:
Wire Diameter
Pitch
Load
Etc....
Things from the dialog used to generate the spring.
(I have a spring in an assembly, but no record of the data used to generate the spring.)
chris31
Thanks for the help.  As always, as soon as I ask for help, I find the answer.
JDMather
So what is the answer?
