Inventor Forum
Composite Yellow Lines
6 REPLIES 6
kevcrain
1408 Views, 6 Replies
How can I make the default yellow lines that occur in a composite change to be the normal black lines?
6 REPLIES 6
in reply to: kevcrain
Are you talking about sketch lines?  What version? Can
you post an example part, zipped?
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP2, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
kevcrain
Here's the file. It is Inventor 2009, and it is the black outline that normally occurs on every part to show its edges. This happens when I import say an iges or other format and select the option to combine everything together into one part. The reason for doing this is that it makes our purchased part library cleaner and easier to manage.
JDMather
Try this one. (pull down the EOP marker)
kevcrain
That's perfect, now how did you do that?
JDMather
You might start here http://www.nxtbook.com/nxtbooks/jam/augiworld0908/ and if you are attending AU this year I will be presenting a class on this stuff http://au.autodesk.com/sessions/detail/3056/ I stitched the surfaces into a solid in the CE. I suspect the part would have stitched automatically with the correct settings on import of the neutral file.
hollyesther
Thanks JD!  Isolating my part and then stitching it worked for me.  🙂
