My coworker gets this error:
He makes a detail. In the enlarged view he makes a sketch. He then makes a break out. Within the enlarged view, in the gap which the break out opened up for clarity of the view, are two components that he wishes to make its hidden lines visible. Doing this locks up his machine and makes a single component turn red. This is new behavior. Is anyone in here have an experience like this? What is causing it? What can be done to resolve it?
Try using the Crop View rather than the Detail Window. Also make sure you are up on all SP's and Hot-Fixes
If I use detail, then the shaped from which I created the enlarged view gets annotated in the originating view. However, if I do as you suggest - make an enlarged base and crop it, then I would be required to sketch the shape and annotation of what it is enlarging in the originating view. This is creating more work for myself. However, you are saying that this will make the performance problem go away? Cropping an enlarged view to annotate detail of a smaller view requires less computing power than using the detail command?
I would just create a Sketch within the main drawing and create a circle or box with the labels to match the label you use for the Cropped view. Make sure you anchor the sketch to model geometry so it moves with the main base view.
It will reduce system overhead a bit as the view is not linked to the base view the way a detail view would be.
Kind of a cheat way to create a detail view that can be controlled easier and will allow for break-out views within the cropped view.
Navigate to the root folder for Inventor in this forum and look for the IdeaStation:
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
