Well according to the dialogue you have them offset in the "row" direction
by 2 mm. Also is your 50.8mm spacing correct? Might not be the answer but
they sure look suspect...
Are the holes a pattern? If so then use the feature pattern option.
Sean Dotson, PE (AICE)
RND Automation & Engineering
www.sdotson.com
www.mcadforums.com
"Troy Grose" wrote in message
news:7340599.1112039474267.JavaMail.jive@jiveforum2.autodesk.com...
> I am running into a really weird issue with the pattern component tool
> I want to patten a bolt into 8 holes, a simply rec. pattern, but IV is
making a mess of this simple task.
> Note the spacing, the first space is double what it should be, but not
just that it is slightly more, and offset in the the other direction as
well.
> Anyone seen this before?
> Troy
