I can easily move component patterns into a folder as long as all patterns are sequential in the browser. However if I create another pattern that belongs to the folder but is created after the original patterns I cannot add it to the folder. If I delete the folder and select the patterns I get an error message if I try to add them to a new folder (remember the patterns are not sequential). I cannot move a pattern in the browser once created and if I move the part into the folder and then create the pattern it moves it back to the bottom of browser. THe net result is I end up with a lot of 'orphaned' patterns.
Is there anyway anyway around this problem?
Solved by mcgyvr. Go to Solution.
Sadly 3+years later the answer is still NO.
http://forums.autodesk.com/t5/Autodesk-Inventor/A-short-letter-from-a-component-pattern/td-p/2821634
