Hi Ian,
It appears there is some problem with the command itself. While the texture
of the part derives correctly, the physical property returns to Default one.
The correct Material can be selected again but the custom properties are
wiped out. It happens using either workflow - with the Component Derive from
assembly or Derive Component in a new part.
Don't know the solution for this one but.
Igor.
Web: www.meqc.com.au
www.boatworks.meqc.com.au
wrote in message news:6281629@discussion.autodesk.com...
Component Derive Template.
Does anyone know how to change the default template that inventor uses when
you invoke the 'Component Derive' command?
Component derive is an excellent command, but when i use it, the part has
different material property and custom parameters that i created in my
standard templates are missing. so i'm assuming that inventor is using
another template for this command.
Thanks in advance.
Ian Schell
