Inventor Forum
Commands Work features is not active in edit base solid
2 REPLIES 2
rgruychev
260 Views, 2 Replies
Commands Work features is not active in edit base solid.
How to make  plane? How to make active ?
2 REPLIES 2
johnsonshiue
in reply to: rgruychev
Hi! When you edit the base solid, you are in a special non-parametric environment. Only limited functionality (local geometric operation like Move Face, Offset, and Expand/Contract) is available there. You might notice that there are no dimensions or parameters there. And, there are not associative features.
If you want to create Work features or any other parametric features, you will need to finish editing base solid and return to parametric enviornment.
Thanks!
Software Test Engineer
rgruychev
Please see this film
http://www.youtube.com/watch?v=ByWO6jR4Lnk
In this version commnd Plane  from Feature menu work .
I want to  use commands from Feature menu.
