Inventor Forum
Command Line Inventor Task Scheduler
2 REPLIES 2
scottmoyse
1650 Views, 2 Replies
A while back someone posted this with no response
http://forums.autodesk.com/t5/Autodesk-Inventor/Task-Scheduler/td-p/1717093
I'm followign up with a more specific subject.
I want to automate the check in of design files to Vault on each PC, prior to running workspace sync (Vault) which does have command line support.
I know you can schedule tasks within the Inventor Task scheduler, but has anyone task scheduled the Inventor Task Scheduler? I suppose in theory you could schedule the launch of Inventor Task scheduler via the Windows one? or is there any need? If the Inventor Task scheduler isn't running, but a task has been scheduled, will it execute the program itself?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
2 REPLIES 2
This can to be done through VBA. If you use the argument /Automation, inventor will start invisible, and you can later get GetActiveObject and do your processing.
>>>Process.Start("C:\Program Files\Autodesk\Inventor 2013\Bin\Inventor.exe", "/Automation"). You may also want to post this question in Inventor customization forum for alternate solutions around starting task scheduler automatically.
Yes it should. Because you are configuring the task to a windows user login. It has to run without task scheduler being initiated.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Yong.Jing
in reply to: scottmoyse
check the Inventor task schedual's properties, It is:
"C:\Program Files\Autodesk\Inventor 2014\Bin\TaskScheduler.exe"
So you could use command to run this program.
You coudl configure the frequence at special time. then all the task could be done by itself
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
