I am working in assembly mode. I have 2 individual parts they overlap together due to assembly requirements. On seeing this, instead of 2 individual parts I want combine and make it into 1 part. Is there any way, I can do combine in assembly file.
Just like using combine command when we have 2 solid parts in a part file.
Solved by mflayler2. Go to Solution.
U can Derive an assy to Single Part File
There is no command to do this. You could make them a subassembly. You could then derive this subassembly into a part file. Or you could use a LOD to do this, so that you can operate on the parts individually and toggle back to the derived part.
Does this help?
couldn't you just create a substitute? thats essentially a combine tool in the assembly environment
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
You guys might be thinking too hard on this.
Open one of these files in context in the assembly.
Start Copy Object
Select the other part still visible in the Assembly and make this a new solid
Then use Combine
Return to the Assembly and delete the other part
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
I am sorry. I am not used to using substitutes. if you don't mind, can you please provide me with a classic example of how to use substitutes. Thank you.
there are some great examples on Youtube and in the help files.
Scott Moyse
