Inventor Forum
Combine Extrusions
6 REPLIES 6
Oakcutter
8326 Views, 6 Replies
Combine Extrusions
In Inventor 2013 I have created two solids in one part thinking I could combine the two into one part. When I click the combine button this error message rears its head, "You must have at least two bodies to combine". Looking at the browser it shows both solids as bodies, What am I doing wrong? Thanks
6 REPLIES 6
rdyson
in reply to: Oakcutter
You didn't post the ipt.
PDSU 2016
Oakcutter
in reply to: rdyson
I have now, thanks.
WHolzwarth
You didn't create Extrusion2 as separate body.
Walter
Walter Holzwarth
JDMather
Workplane1 is not needed.
Sketch2 is not constrained and has sick (pink) geometry.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Oakcutter
in reply to: WHolzwarth
Thanks Walter, you were right on, appreciate all the help I can get.
Oakcutter
in reply to: JDMather
JD,
I've gone half way thru the 60 tips and I must say what you sent is invaluable I would encourage any newbie to go thru that before doing another thing in Inventor.
