Inventor General Discussion
Valued Contributor
Mike686
Message 1 of 13 (1,623 Views)
color scheme editor....
1623 Views, 12 Replies
10-31-2012 07:31 PM
hi, i need help..
i was searching for a way to change the color of the project geometry,,
i've found this via the cad setter out
http://opendesignproject.org/2010/09/02/creating-a-new-application-color-scheme-in-autodesk-inventor...
i have install the color scheme editor
i did a backup of the registry using the reg export and save it elsewhere in my cpu
i've made one change to a color then it save
when i open inventor all the color scheme are messed up...
i was using winter night...and now my background color is green....in the part/assembly environement as well as in the drawing environnment...
i've try reopening the color scheme editor, fisrt it wont stop showing error message.. and even after i import the reg back up i've made and the change i've made is back to what it was before
i still have the green background...
i've also try to repair the program witch change nothing..
before reinstalling what can i do
please help
Product Design Suite 2013
PaulMunford
Message 2 of 13 (1,600 Views)
Re: color scheme editor....
11-01-2012 05:57 AM in reply to: Mike686
Sorry to hear that Mike - I hope someone from Autodesk will be able to help you...
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Valued Contributor
Mike686
Message 3 of 13 (1,581 Views)
11-01-2012 06:10 AM in reply to: PaulMunford
do you have any suggestion on that paul?
if i reinstall inventor would it solve this problem...
and what am i going to loose in the process??
i'm really stuck with this one , and i need to work with inventor today....
philip.s
Message 4 of 13 (1,543 Views)
11-01-2012 10:07 AM in reply to: Mike686
Hi Mike,
This isn't going to be much help but I wanted to let you know that we looked into this and received the following response (taken from the Readme file of the bonus tools).
“While Autodesk, Inc. has made reasonable efforts to verify and test the sample files ("Sample Files") and tools, including wizards (collectively "Tools") provided in this SDK, the SDK is provided solely on an "as is" basis, "with all faults". The SDK, the sample files and tools contained are employed at the sole risk of the user. Autodesk disclaims all express or implied conditions, representations, and warranties of any kind, including any implied warranty or condition or merchantability, fitness for a particular purpose, or no infringement. The user is free to modify or customize the sample files provided, however Autodesk makes no representations, warranties, conditions or guaranties as to the quality, suitability for a particular purpose, or safety of user's other applications or data when used with the sample files or the tools.”
Again I know that's not what you wanted to hear, but I'm hoping that we can get additional community involvement on this thread to discover a potential workaround.
Philip Schmelzer
Valued Contributor
Mike686
Message 5 of 13 (1,534 Views)
11-01-2012 10:41 AM in reply to: philip.s
i understand...
but autodesk must know a way to reset the change made buy this application , no?
but now i must find a way to undo the damage
i don't really want to do it but if i uninstall inventor and reinstall it, will that restore my color
if i would have know it will cost me that much trouble just to change the color of some line
let me tell you that i wouldnt done it
and why do we need an outside application to change what color that type of line use etc....
Valued Mentor
japike
Message 6 of 13 (1,519 Views)
11-01-2012 11:05 AM in reply to: Mike686
Did you do a backup of the entire registry?
Is it possible that you didn't have write access to a portion of the registry when you tried to restore the registry? Where you using an administrator account?
Peace,
Jeff
Inventor 2013
Valued Contributor
Mike686
Message 7 of 13 (1,515 Views)
11-01-2012 11:14 AM in reply to: japike
yes i did a backup as and how they suggest it when opening the read me file with the color scheme editor...
and for the adminstrator part... inventor is install on my computer, i dont have server or limitation since i work alone..
but if you need to set some thing up to have the possibility to rewrite the registry, then i'm not sure i was autorize to write access
whats weird is when i reopen the color scheme editor everything seem fine, the color show for each scheme seems ok..
and when i open a part file, check the attachements to see what i see
PaulMunford
Message 8 of 13 (1,483 Views)
11-01-2012 12:57 PM in reply to: Mike686
Hmm,
Thant could be caused by Inventor using the wrong background picture?
This post explains the steps to change it...
http://inventortrenches.blogspot.co.uk/2012/09/inventor-background-color-as-white.html
Valued Contributor
Mike686
Message 9 of 13 (1,476 Views)
11-01-2012 01:15 PM in reply to: PaulMunford
it the same in ipt, iam and dwg
Valued Contributor
Mike686
Message 10 of 13 (1,473 Views)
11-01-2012 01:17 PM in reply to: Mike686
i try changing the background color..
no matter the one i select, background still green
