Inventor General Discussion
Active Member
0 Kudos
Post 1 of 13
Color changes Inventor 2013
7949 Views, 12 Replies
06-28-2012 06:36 AM
I’ve installed Autodesk 2013 last Friday.
It looks great, but Inventor changed the Colors and Materials and that’s not fun.
This is a rendering with inventor 2013.
The profile right is designed in Inventor 2012
The profile left is designed in Inventot 2013
They have the same colors.
Entire profile is Aluminum flat and the tops are Aluminium polished.
Does anyone know what I can change?
Regards
Pieter
Distinguished Mentor
50 Kudos
Post 2 of 13
Re: Color changes Inventor 2013
06-28-2012 09:57 AM in reply to: pieterhuyck8342
Select the faces you want to change, then right-click and select properties.
You can then set the face appearance.
Or you can select the faces and then change the appearance in the appearance drop down list.
John Retzlaff
430 Kudos
Post 3 of 13
06-28-2012 11:15 PM in reply to: pieterhuyck8342
Did you update the color styles in your 2012 file?
(function is on the manage tab > styles and standards block > update)
Inventor 2013 ask if you want to update to the new manner of color management, but doesn't necessarily update the existing colors afaik.
Nice looking profiles btw. :smileyhappy:
Using IV2015 Pro SP1 - upd.2, Win7-64bit
Active Member
0 Kudos
Post 4 of 13
06-28-2012 11:54 PM in reply to: pieterhuyck8342
Dear John,
The top-faces already were in the Aluminium Polished appearance.
Thanks anyway.
Regards
Active Member
0 Kudos
Post 5 of 13
06-28-2012 11:56 PM in reply to: -niels-
Dear Niels,
The styles were up to date.
Thanks anyway.
Regards
889 Kudos
Post 6 of 13
06-29-2012 10:47 AM in reply to: pieterhuyck8342
2013 doesn't migrate the colors right. Just clear any overrides and redo them as needed. It's a PITA, I know, but that's all I've been able to figure out myself.
Mike (not Matt) Rattray
Product Support
47 Kudos
Post 7 of 13
07-11-2012 02:14 PM in reply to: mrattray
Can we get a small data set please?
You mention "render". Is it because you only see this in Studio Render?
You also did not mention if you use Shaded view style or Realistic view style.
I also hope you are at the 2013 Update1 level.
Bob
Active Contributor
1 Kudo
Post 8 of 13
07-11-2012 03:05 PM in reply to: mrattray
This is actually something that I think we need to do at our office.  We've got a style library that I think we need to recreate from scratch.  Any suggestions on the best way to tackle this task?
Board Manager
0 Kudos
Post 9 of 13
07-13-2012 09:14 AM in reply to: pieterhuyck8342
We've created some expanded documentation to provide more guidance on the new materials and appearances tools.  I've attached it here, and am in the process of getting it uploaded to Autodesk.com.  It should clear up several of the questions that have been raised on this board around this enhanced functionality.
Thanks to Chris Mitchell and Bill Bogan for writing and reviewing the content.  Please take a look and provide feedback on the documentation usefulness.
In addition, we've updated the wikihelp files with this information as well.
FAQ Part 1
FAQ Part II
Data Migration > What’s Changed in R2013
Data Migration > Inventor 2013
Data Migration > Migrate Color Styles to Appearances and Migrate Material Styles to Materials
Data Migration > Migrating Content Center custom materials and appearances
Manage Materials and Appearances
2013 Library Management Methods
Migration Mapping – Materials
Migration Mapping - Appearances
Pete Lord
Product Manager
198 Kudos
Post 10 of 13
07-19-2012 05:45 AM in reply to: prestonlord59
Thanks for some further clearance here, Pete.
I've searched the German Wikihelp for similar stuff, but I think, it still needs to be translated. I couldn't find anything until now.
Some kind of help for me is the comparison list between color styles and appearances. But it's not enough for localized Inventor versions.
I'd appreciate a comparison list in Excel as follows:
Color style name (engl.) - Color style name (localized) - Color look in 2012 (taken as screenshot) - Appearance name (engl.) - Appearance name (localized) - Color look in 2013 (as screenshot). I can sort that list in Excel to my personal needs.
Greatly important are those screenshots for me. Looking at your list, I can suppose, that old Yellow (dark) is looking the same as 2013 Yellow. But it isn't. And there are several others with a complete new look.
Walter
