Inventor General Discussion
Distinguished Contributor
cadcamm99
Message 1 of 2 (830 Views)
Color change with iLogic
830 Views, 1 Replies
06-27-2012 01:40 PM
I am using Inventor 2012:  I have a table with different part numbers. I want to create an iLogic rule to change the color of second solid body in my part for a specific part number.
This is what I did.
If iProperties.Value("Project", "Part Number") = "F22111796" Then
 Feature.Color("plastic")= "Gray"
ElseIf iProperties.Value("Project", "Part Number") = "F22111796V" Then
 Feature.Color("plastic")= "Gray (Dark)"
ElseIf iProperties.Value("Project", "Part Number") = "F22111796N" Then
 Feature.Color("plastic")= "Gray (Light)"
Else
 Feature.Color("plastic")="Gray"
End If
However it does not change the color of the second solid body when I make the part number active. Any ideas?
Curtis_Waguespack
Message 2 of 2 (822 Views)
Re: Color change with iLogic
06-27-2012 03:26 PM in reply to: cadcamm99
Hi cadcamm99,
It works fine for me. I'd check to see if you have a feature color override or solid color override that is causing an issue. Attached is a test file for you to compare.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
