Solved by mpatchus. Go to Solution.
First create the coil, then create sweeps from the ends of the coil for the inlet & outlets.
See attached file
I would use a Coil Surface body as Sweep rather than Coil solid directly or if using Coil solid change the end conditions to have at least a short flat section. This ensures that the profile is round rather than elliptical.
