One of my users is having an issue with levels of detial. The mass of the assembly LOD is updated on the idw, but the center of gravity is not. What could the issue be?
Lenovo D20 or D30 workstations
nVidia Quadro 4000
8.0 GB RAM
Inventor R2013 update 4 for SP 2.0
Its could be possible the file is corrupted. Try deleting the view and replacing it. Also you can try a new IDW to see if the same placed view reacts the same. Also see if you defered update might be set for the view in that particular file. One other thing you can try is to run the Assembly and all referenced files through the "Task Schedular" > "Migration Task". Choose the options "Total rebuild" and "Compact Model History" for the options. Then try reopening the original file in question.
Regards.
Don
