Hi
The part is a clear piece of glass used on a gauge.Is there a way to have the number appear more clearer/brighter.I want the number behind the glass.Can the number be much clearer/brighter
Regards
Paul
Solved by Ray_Feiler. Go to Solution.
Helpful hint: Always post the version of Inventor you are using, especially when posting files. I can see that yours is 2014.... many of us are still on earlier releases and won't be able to open your part. Posting the release will just make it easier for those who CAN help you to get to your files. Thanks, and good luck! 🙂
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
yes 2014...my apologies
The picture attached shows how dim the black color is from behind the glass part
What glass appearance are you using? There are several clear appearances that can be applied. None will be perfect, I fear, but if you try several, you may find one that gets you closer to the desired look.
Chris Benner
Try Clear - Light
You also can cheat by moving the text to the front of the glass.
@paul_pearson wrote:
....I want the number behind the glass.Can the number be much clearer/brighter
How will the text be manufactured on the real part?
Is is printed/painted? (if so, it has a thickness. What is the real world thickness? It is also most likely a different material (the ink/paint) than the substrate glass or plastic)
I haven't experimented since Autodesk changed the colors, but there is a thread here somewhere with clear&.bmp in the body that might be relevant.
Thanks all
The glass cover will be covering a digital gauge reader which has black ink numbers like a digital watch
Paul
