I`m trying to add a circular pattern to my extruded cylinder. My goal is to get 0,5 mm holes in a circle pattern with 14 in placement and 360 degrees. When I add the circular pattern, nothing happens other than the circular pattern feature added to the browser.
Can someone please look into my file and maybe tell me how to solve this.
Thanks in advance!
Solved by JDMather. Go to Solution.
Solved by mdavis22569. Go to Solution.
Please try to always mention the Version of Inventor in your posts that contain parts. I am guessing this was done in 2014? This way you'll get the right people helping you out. For example, I can't open your model since I'm still on 2013.
Anyone on 2014 want to take a look?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
You logic does not make sense to me.
The hole is in the center of the cylinder?
Not quite what I had in mind. I want to have the same pattern as the one on the image below. (Found on the internet)
Thanks for helping!
Something like this?
Michael solution looked too much like work to me!
R2013 solution for ChrisB
It is all in the feature tree.
And here
http://home.pct.edu/~jmather/skillsusa%20university.pdf
