Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 3
circular pattern
341 Views, 2 Replies
01-19-2013 04:26 AM
On the circular pattern i used 10 increments @ 300 degrees....why does the 10th increment not line up at the 10th position...have i got the maths wrong?
Please see attached
Simon
Hi  simon_toaldo,
You'll need to adjust for the angle of the extrusion, to consider the pattern start point. Here I've created a driven dimension called d67, which has a value of 1.59 degrees and then I subtracted that from the 300 degrees in the pattern.
I hope this helps.
Curtis
1,706 Kudos
Post 2 of 3
Re: circular pattern
01-19-2013 07:16 AM in reply to: simon_toaldo
Hi  simon_toaldo,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
0 Kudos
Post 3 of 3
01-21-2013 04:22 AM in reply to: simon_toaldo
Thanks Curtis
