Inventor Forum
circular pattern problem
4 REPLIES 4
Hidayah
756 Views, 4 Replies
Dear all,
Can anyone help me on this, we have a problems when we tried to do a circular pattern with our 3D drawing but couldn't generate it.
Attached is the files.  this is an i-part. Problem started when sizes reach 180M.
We can't figure out why is this happening. Please advise.
4 REPLIES 4
salariua
in reply to: Hidayah
I think it's because the ribs are totally inside the legs and as the error shows: " there are not meaningful edges to be made from the intersection".
If you do the ribs as separate body it works (don't know how that's going to affect you).
You can also add the legs towards the end of the part as late possible.
Other options:
Suppress pattern components that intersect the legs but that's hard on ipart, need to check all instances.
Do the pattern in separate operations, do you really need the ribs underneath in-between the legs?
Why are you having the pattern symmetric both ways 360 deg?
Rename some of the features as you make them, it's easyer to find and edit by others.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Hidayah
in reply to: salariua
Thanks for the ideas, will check on its again.
Actually, this part is design by our customer and he's having this problems and ask me to help him.
Hidayah
Dear All,
We manage to get solution for this problems, It’s the sketch that causing problem. The Sketch for the rib is too near to the projected line.
Thanks!
JDMather
I would not use projected geometry from solids in this design if possible.
When I looked over the file it appeared to me that all, or nearly all, of the sketches could be created on the Origin workplanes without ANY solid geometry.  I think on this design I would (should) be able to delete all of the features, yet nearly all the information to create the geometry would still be available in the remaining sketches and the sketches would not be "sick".
All about parent/child relationships of geometry.
