Rob,
You are right. It did work in R6Sp2. I have logged a defect against this
issue. Thanks for pointing out the defect.
Raj kumar Ilanchelian,
SQA Engineer,
Autodesk, Inc.
"Rob Singlehurst" wrote in message
news:0056FA8855E52B0D316426D4AB3CD0F6@in.WebX.maYIadrTaRb...
> Thanks Kent,
> I'll try that combination from now on. But it did used to work as I
> described. When initially selecting a face to sketch on the edges would
be
> projected and I would use them to reference other geometry off of.
Perhaps
> someone has decided that it was broken before and now it's been fixed -
> (like the shaded view lineweight thing!!)
> Cheers,
> --Rob Singlehurst
> "Kent Keller" wrote in message
> news:929E2C877B05F4EFD2C913162E5FFC05@in.WebX.maYIadrTaRb...
> > It was still constrained when I went back into the sketch a second time.
> > I always run with Autoproject edges checked and Automatic reference
> unchecked. Just what
> > seems to work out best for me. 8^)
> > Kent
> > Assistant Moderator
> > Autodesk Discussion Forum Moderator Program
