Has anyone figured this one out? I have a view that's in perspective and when I add a circle detail the outcome is a misaligned host and dependent (see attachment A). The only way I've found to correct this is to move the host circle detail until the dependant shows what I want (see attachment B)...but I still end up with a misalignment. Can't find anything in the properties dialog box.
I'm out of ideas!
Solved by t_pcoll. Go to Solution.
Very odd indeed. First check that you have all the SP's and Hot-Fixes for your version of Inventor. Can you post a screen capture of the IAM with the Origin Planes visible.
@Anonymous wrote:
You won't receive updates, this have never really worked as long as I have used Inventor (IV4).
Shall we notify Autodesk that their Service Pack Notification system needs a Service Pack, or does it have to be submitted to the Department of Redundancy Department instead?
That's a good idea. If push comes to shove I'll probably create the iso. Thank you.
Autodesk Customer Service is on the case as well. Sounds like it could be my model. We'll see.
I attached the project files if you'd like to take a stab at it.
The file is too large so you'd have to download them from the following link:
Any particular reason to use the Presentation file for the ISO view. Not sure if this is the reason for the problem.
Sorry Blair...it got a little crazy around here. We used the presentation file because we needed to turn material's on/off on every view. Is there another way?
