I created a tabulated drawing for a punch that can be different diameters depending the -x at the end of the p/n.
What I've done in the past is simply hidden the dimension value and wrote in whatever I named that dimension in the iParts table. In this case, DIM_A. Unfortunately this time I need to change the default tolerance to +0.0000 -0.0003. But when the dimension value is hidden so is the tolerance. How do I get it to properly read DIM_A +0.0000 -0.0003 without the -1 dimension listed?
