Thank for the reply Larry, but that doesn't work.
As I explained, it will change the font of the particular view label, but
doesn't affect the font size of the associated label in the parent view.
For example: creating a detail view from another view. the new detail view
has a label, and the original 'un detailed' view has a corresponding label.
You can edit the font size e.t.c in the detail view, but it has no effect to
the font size on the label 'Detail-X'. But the actual text will respond to
changes.
"Larry Caldwell" wrote in message
news:9926BB2F0F4192035B29368E0E8BF804@in.WebX.maYIadrTaRb...
> RMB on label/Edit View Label (something) highlight text (actually <<<)
> change size in test size field.
> ~Larry
> "Derek Burns" wrote in message
> news:2A4872827C2E5C6084C8CD9FC3E81F3C@in.WebX.maYIadrTaRb...
> > does anyone know which parameter controls the default font for a view
> label
> > when a new view is created? I can edit it after it is created on an
> > ortographic view, but it seems impossible to change when a detail view
or
> > section is created. The corresponding text changes ok, but font size
stays
> > the same default (4.5).
> > Thanks in advance.
> > Derek Burns
> > UK
